Ecomike
NAXJA# 2091
- MilkyWay Galaxy
My 1987 Wagoner, new battery, cranks fine (Engine cranks, starter cranks), radio works, AC/Heat blower works, but does not start/run.
Also no brake lights or tail lights.
Got suspicious and found no Zero fuel at the fuel rail. I do not hear the fuel pump run when I turn the Ignition switch to run.
Been ages since I was an expert on the wiring, and going to dig into it tomorrow. Needs some quick ideas please.
I ran and drove fine when I parked it months ago.
Gotta be a common electrical issue, relay under the hood, or fuse under the dash. Ignition switch is not that old or overloaded like the old days..
Glad to see some folks kept the lights on here.
