kd5dwy
- Central Arkansas
I have a Dana 44 axle that I pulled from an '87 Wagoneer from a local junkyard. I have removed the drums, pulled the axles and cleaned/painted the housing. I threw away the drums since I was going to put on disc brakes. It has an open carrier and the diff cover has a large dent in it (no damage to the gears underneath). It has a 3.54 gear ratio.
I would like $200 for the axle and you will be responsible for delivery.
I also have a Dana 30 with a bad hub. It is an '87 with vacuum disconnect (working). This axle is free for the taking. You will be responsible for delivery.
