xjnation said:
90% of your posts are how bitchin your junk is....yet for a name of DYNO, we have never seen actual graph and numbers, just alot of hearsay.
CRASH said:
I agree with xjnation (dear gawd, did I just say that?). Your incessant insertion of stroker comments in every engine thread is getting annoying. Also, quite frankly, i don't believe your power numbers. Your calculated figures just do not work in the real world. My conservative estimate is that a stroker built for trail use puts out MAYBE 40 more horsepower to the rear wheels. So my original Renix 177 goes to 207 at the crank. Run that power through a heavy duty drivetrain, and 35+ inch mud tires, and I bet you see about 150 HP at the wheels. Please show me a dyno sheet with torque curves, and we can discuss further.
That's because I was living in Saudi Arabia until two months or so ago and I didn't have access to a dyno. Now that I'm living in the UAE, the nearest Dynojet dyno is just 1-1/2 hour's drive away in Dubai so I'll get some real chassis dyno numbers when the weather cools off a bit (it's still over 110*F here in the daytime). I'm curious to see if my HP/TQ estimates are close.
You're forgetting that my stroker has been breathed upon rather more (ported '92 head, 65mm Mustang TB, 2.5" exhaust) than many strokers so comparing it to a Renix-based stroker with a tiny Renix 51mm TB and unported Renix head is pointless.
I also have 27.4" street tires (225/70R15H), not 35" mudders, and I have an AX-15 5-speed tranny, not the AW4 auto, so my drivetrain HP/TQ losses are a lot less.
xjnation said:
Most the guys here would not be able to afford to build a seperate long block then swap it in at our leisure.
Considering it would cost less than $400 to buy a junkyard longblock and maybe $1600 in parts and machine shop costs to build the stroker, that's a total of $2000 which you can spread over a few months.
xjnation said:
As for a V8 swap. Down time?
If the entire swap vehicle was available as suggested the swap would be fairly painless and could be done in a long weekend being able to
That's a big IF. Not many people can find a swap vehicle that easily nor do they have the fabrication skills and facilities to do it. As I said in an earlier post, I'm not against V8 swaps. In fact, I think they're cool when done properly but it's misleading to think that you can do it in a weekend and get everything, especially the electrics and gauges, running properly.
I also feel that if you're gonna swap in a V8, it should have a displacement that's much higher than that achievable from a stroker (like the Chevy 350 SBC or the Dodge/Jeep Magnum 5.9 V8) so that the potential HP/TQ gains are that much greater. Why swap in a WJ 4.7 V8 when you can build a Jeep 4.7 I6 that's more powerful?
xjnation said:
and for your info many of us actually drive our rigs, my 96 gets more miles per week than yours sees in a mont it would appear and 250,000 mile 95 and 96's are very common. We average 40,000 to 50,000 miles a year on ours
So you drive 1000 miles a week? Good for you. I drive my XJ every day and I still manage to drive 1200 miles/month despite not having to commute to work. FYI, that's still more than the average driver does.
