XJoshua
- Pueblo, CO; USA
Since strokers seem to be the in thing to do, and people have been asking questions I think its time for a update, and for me to ask a few more questions.
So from where we left off I still had the cam, lifters, head assembled, and freeze plugs installed. I will admit its taken me a long time to get things moving due to it being freezing cold oldside and been working alot more at work then I used to.
Where am I now? I have every thing removed! Nothing but metal exists, except the front seal on the timming chain cover, but Im going to torch it out since tools are moving it. Im acid dipping all my parts with this mirical purple stuff which gets thing pretty clean and degreased. Still have several bags of stuff to clean, and tuesday Ill be calling around for quotes on machine work.
Picture Time:
Now as for some questions for the experienced stroker builders. What is the best chemical to remove oil stains from a asphault garage, and does this sound like everything I need done and did I miss anything? Also the port and polish Ill be doing myself...
Valve Cover-
Acid Dip
Head-
Hot Tank
Check Deck
Block-
Hot Tank
Shave Deck(9.433 - 0.020")
Bore(3.905 - 0.030") & Hone
Install Freeze Plugs
Install Cam Bearings
Rods & Pistons-
Balance Rods
Weight Match Rods
Increase Piston Dish Volume(13cc TO 22cc)
Weight Match Pistons
Press Pistons To Rods
Crankshaft-
Check Clearance
Balance
Oil Pan-
Acid Dip
EDIT: On the 4.0Performance site it mentions he reused his head bolts. Im pretty sure reusing head bolts is like reusing a condom, its a No No! Am I right, or do we 4.0L people have strong head bolts?
Picture Time:
Valve Cover-
Acid Dip
Head-
Hot Tank
Check Deck
Block-
Hot Tank
Rods & Pistons-
Balance Rods
Weight Match Rods
Crankshaft-
Check Clearance
Balance
Oil Pan-
Acid Dip
