4.0 CCV/PCV part numbers
heartbt
I had to do some research to find these numbers, so to help others, and help me remember, I'm putting it here.
AFAIK these numbers apply for the 90-97 second gen xj.
These are the push in style elbows, I don't have the 1/2 turn, so I didn't look them up.
Grommets:
Napa BK6301410 or Napa BK6301411
Front elbow:
Napa CRB29574 or (One is taller than the other)
Napa 6301078 or
Dorman 47079 or
Chrysler 53030591
Rear elbow(the actual CCV valve):
Napa 6301076
Dorman 47057
Chrysler 53030492
Front Hose: (may have a Napa/Echlin cross, but I did not look for it)
Chrysler 53006239
Rear Hose: (as an assembly, also has the Map sensor hose. No after market avail, AFAIK. If anyone knows of one...)
Chysler 53030726
I think those part numbers would be for 94-01 for Cherokees (except for the last "hose assembly"); Wranglers also used some of the same parts through 04 or 06.
The Dorman grommet numbers are 42344/2946079.
edit- I only pay attention to the numbers I need for my 97, so 94-01 may not be completely accurate, but the part numbers have all been posted here at some point if you do some searching (I replaced mine last year, got all the parts off the shelf at local stores). Advance, and Autozone carry the Dorman stuff, NAPA the Belkamp stuff, Rock Auto has Dorman as well, and TeamCherokee also lists a bunch of stuff (OEM numbers, not sure if they're NOS or replacements). Prices are good, no idea on shipping and availability though. http://www.teamcherokee.com/Emissions/index.html
