- San Bruno, CA.
Hey, that's one of them funky splined D30 shafts.
I've only seen those in a few XJs.
hightimes2 said:I have done several 8+ trails in Colorado.
Jes said:Hey, that's one of them funky splined D30 shafts.
Jes said:What trails(not that I know what 8+ means)?
hightimes2 said:carnage canyon in boulder, spring creek, wheeler lake, Old chinamans culch
anywhere from 8-10Jes said:Those are 8+?
What does Montrose rate?
OneTonXJ said:Lincoln, I'll get back with you on the eaton theory. I've got one sitting out back and I'm pretty sure it's going to go into a full on rock bus w a big block in it. That axle is super stout, especially for its weight. I don't know if you've actually put one of those shafts in your hand, but they are massive on a visual standpoint. The southern boys with the super heavy hybrids running on 44's and massive powerplants love that axle. And don't give me the slippery rocks crap cuz when you're running up lower 2 at WOT and not getting the snappy snappy, you're running one hell of an axle.
Goatman said:I ran the entire Chinamans Gulch trail in 2wd. It's not 8+ in 2wd let alone 4wd. If that's an 8 then Die Trying in Montrose is a 25.
Kudos to you, though, for having an easy right foot. Some are able to do that and some aren't.
David Taylor said:I think the real trick will be getting the warm hubs to hold up. I already busted one last weekend. The warns look like junk on the inside, and they are the premium ones. I might go back to the stock Fords. It looks like they have alot more beef.
BrettM said:My understanding is the OEM Ford hubs are the strongest available for the D44, but is yours trailered? You could just do drive flanges from a Waggy.
