831_xj
- Santa Cruz
Don't get your panties wadded up Hulk
I always figured the transmission was a strong part.
I do listen though, even though I have a thick skull.
Trans cooler has been ordered already.
And looking at gears now, they are less expensive than I expected, and hopefully YouTube can teach me to install.
And going to stick to 33's.
4.56 probably better than 4.10, or can you go too far the other way with gears too?
Makes sense that I'd have to hit everything with more throttle since I wouldn't be able to crawl either.
Its clear you have no idea how tires work. Super Swampers were great tires when they came out in 1970, but that is a shitty tire by todays standards.
If your ragging on Swampers then you have obviously never run them before. They are built for one thing, mud, and they do that exceptionally well. Hands down no other tire is going to do better in the mud. The only thing that will come close are ag tires, and that's a completely different animal.
I understand that professional offroad racers like Ultra4 don't run them, but that is because they are not race tires. However the guys at TTC are running boggers and I would say they have enough experience to qualify as professionals.
Give credit where credit is due. Interco Tire, or Swampers, makes a damn good mud tire that has stood the test of time.
FWIW I am running BFG KM2s 33s on stock HPD30 and 8.25. Been running it for over a year and have yet to break anything. My experience from Swampers comes from the 39.5 TSLs that I ran on a 93 Bronco locked with ARBs on both ends and a Ford Racing 351 under the hood.
33's is the best tire size. the move to 35's usually dictates building axles. 33's can live on a stock d30 as long as you're not a moron.
an AW4 is probably the most durable overdrive auto trans on the planet. Seriously, I hate all things auto trans and I have respect for the abuse an AW4 can take and not even flinch. That said, heat kills fluid, and crap fluid takes out the clutches. No way around that. Torque converters make an extraordinary amount of heat when they do their thing, and with stock gears on 33's its gonna slip a ton.
The only good thing about 4.10s is that you can find them in junkyard axles. Otherwise, 4.56 all day long. Don't be afraid to run a 4.0 at 2500+ rpm on the highway. The lower gears will mean sooner converter lockup and less unlocking on hills. The more a torque converter stays locked the less heat, the less heat the longer your trans is going to live.
and swampers still = lastara
I have to agree with kat stain on the TTC guys. A great event to watch, always a good show ..... not professionals.
On the AW4 a great trans yes, but not a 400+ HP trans as guys claim. Last year we took the Ultra4 stock class series championship in an XJ with just shy of 400 horsepower, and basically went through an AW4 every race. More than once we came over the finish line with no 2nd gear and at half throttle just hoping to make it there. We think we have the right combination of upgrade and aftermarket parts now to make it hold up .. but time will tell.
The only swampers worth anything are stickies.....otherwise the only thing worse than swampers are Falcons![]()
Supra's are running roughly 255/40/17 tires so I wouldn't see an issue with the AW4 there, however with 400hp and 35's, or bigger yeah I could see where you would go through them. But hey Ive never owned a Supra with 400hp so what do I know.
surprisingly the falcon wildpeaks do better in the mud than our mtr/k's did..
We're running 5.38's, so I wouldnt expect the size of the 35's to be a big effect on the trans. I think its more the torque converter has a hard time with shockloading (disabling lockup permanently helped) and the higher RPM's into the pump overpressure the solenoids and they pop open at the wrong times, causing eradic problems.
We did strait up burn one up, but to its credit our transmission cooler fan failed .. on the starting line! .. we raced the entire king of the hammers with effectively no cooling. It finished the race with our fingers crossed, but then failed giving some press guys a ride the next morning.
