Re: Re: 33" vs 35" On stock drivetrain?
it sounds like your into the BDMT thing, so do what youd like. youll learn down the road...
I don't know what BDMT is.
33/35's on stock gears is going to kill your trans.
it's also going to end up with you breaking a lot more stuff because you will have no crawling ability. Everything you do will be attempted at full throttle because that's the only way you can get your your junk to move. Full throttle+33+D30=:explosion:
I loved skinny super swampers, but they are not the best tire ever.
KM2s cut sidewalls on the regular, I know several people that have cut them on mild things.
MTRs are the current fawesome tire and everyone I've seen wih them has been happy. unless you're going sticky treps or krawlers that's the tire you want for general trail riding/on/offroad use.
I'll say this, you have no comprehension of gearing and torque and how it applies to your drivetrain. listen to the previous posters, or just become another askhole that asks for expert advice and then proceeds with their own dumb plan that they had in mind before asking.
I always figured the transmission was a strong part.
I do listen though, even though I have a thick skull.
Trans cooler has been ordered already.
And looking at gears now, they are less expensive than I expected, and hopefully YouTube can teach me to install.
And going to stick to 33's.
4.56 probably better than 4.10, or can you go too far the other way with gears too?
Makes sense that I'd have to hit everything with more throttle since I wouldn't be able to crawl either.
The tire choice is another thread really, and muskeg is a no win.
My goal is to make it down hunting trails that I can currently only make when it's frozen.
What I have come to understand about jeep building:
It's a lot cheaper to do it right the first time, than to continually keep re half assing it
Might as well go with those 40" tractor tires now.
If the stock gears aren't that bad with 5 extra inches of diameter, 10 shouldn't be a big deal.
The mass of the tire rotating is a "fake force"
Should be legit.
Just upgrade to the zj cv axle shafts so they hopefully don't blow your ball joints apart the first time those bad meats find traction.
I don't, and never have had any intentions on running that large a tire on stock axles. There is an xj running around on 40" agro tires in Alaska on jeep forum, he doesn't have power issues. But maybe I'm way off base.
I don't plan on one tons for a couple or more years.
