- San Diego
Last few months ive been working on fabbing a 3-link and making a completely flat belly. I also wanted the crossmember to have a removable center. Here's how it started
2x6x1/4" box. I recessed where the trans mount goes. I then added link mount. The lowers are from Barnes and I made the upper.
I ended up having to trim the top side of the drivers lower mount for the driveshaft. I have about 5 inches of separation at the frame and 9 at the axle
The axle side upper bracket is 2.5x2.5x1/4 wall.
I also plated the inner frame rails with some angle iron I had
After mocking it into place I had to cut the floor to make the upper fit
As you can see the exhaust is a tight fit and was kind of an after thought. Luckily I had enough room to make it work
I also clocked the transfer case, which I swapped out my 242 for a 231 due to size. I never saw the two side by side so I had no idea how much bigger the 242 really was.
I used the IRO clocking jig which was very easy. I clocked it a lot so I also had to cut the floor for that.
The black frame is something I made to relocate my seat forward about an inch. The tcase was hitting the seat frame initially.
Got everything all welded up. I got the 3-link kit from Ruffstuff. The upper is 1.75"x.120 wall and lowers 2"x.25 wall. For now I'm using the factory LCA brackets at the axl. They have mini skids on them but u plan on putting new ones on that done hang below the tube.
Now since this was my first suspension build, there was some oversight. Main one being that my lowers barely hit the frame where the old LCA mounts were. Not major so I'm going to cut a little out and weld in some plate.
I also moved the axle forward so my coils were bowed anymore. This extra length required a new front driveshaft but also now makes my trackbar and diff make contact when compressed. So I will be moving the frame bracket forward a few inches.
Also with raising everything up, the t-case linkage was another issue. I had already ordered the boostwerks kit. Turns out that the amount I raised everything in relation to the tcase shifter effected the angle enough so that I do not have enough throw to engage all modes. Ordered the novak cable shifter.
That's all I can think of right now. I'll update it when I fix my little issues. Hope this helps anyone thinking of making a 3-link
