3.5" lift affected dash lights??
KimberleyCrusader said:
The park & hand brake dash lights are permanently on??
This happen to anyone else?
Anybody got some instruction on where to start?
Thanks!
Loosen up the e-brake cable. It's pulled tight from the lift.
E brake cable needs to be readjusted.........
I just loosened the cable but the lights are still on.
Pulled the console out and disconnected the switch to the ebrake, both lights still on
I just read low fluid or an imbalance can cause this too but would this affect the brake & park light or just the brake light?
i have yet to bleed the brakes after the install so I assume that is the prob but I would like to clarify this affecting both lights while the car is apart.
Thanks
If your master cylinder is seeing a pressure differential you would get that light - try having some one help you bleed the the brakes or get some speedbleeders (they have a check valve built into the bleed screw) and bleed the system really well (did you happen to run the m/c dry at any point???)
What does the pedal feel like? good and firm; or kinda mushy?
As for the e-brake switch is just uses a spring contact to ground out when the lever is pulled up - if the contact was bent during removal the light would be permenantly on...
HTH
Matt
PS: check to see any of the wiring with the m/c did not get pinched or shorted and the pug is attatched to the poportioning valve...
