2WD driveline bind after turning off 4WD???
exactly actually the only nuts are the 23 or 22mm axle shaft bolts. Those are the only nuts that you need to remove in order to take apart the differential. Also my drivers side bearing/ hub completely fell apart when I was picking it up to put it back on. So, that could have been my wobble problem from the start.
