2001 Jeep Cherokee Part Ouy
Is there a wiring run from the speedo sensor to the main harness in the engine bay? Should be a 2-wire plug to plug. Trying to fine one to replace my 91 wiring run but not sure if they are the same after the body switch. On mine it's a black/blue and a white/red.
I don't see wiring like that on this xj. Must be an early model thing, as you alluded to.
Sent from my SM-G928V using Tapatalk
Quick run down of what is gone:
Headlight wiring harness
Rear license plate trim bracket/bezel
Rear axle
Wheels and tires
Cam sensor
Alternator
Coil Rail
Transfer case/auto trans gear selector bezels
Front Axle
Front Seats
Transfer Case
I need wiring harness. Can you send me a pic of you bad portion. My is all melted in the area about the intake. So my injector portion, temp, and whatever else is all wacko. It's misfiring, that's how I figured it out. Email me pics if you can. [email protected]
Rear axle
Wheels and tires
Cam sensor
Alternator
Coil Rail
Front Axle
Front Seats
Transfer Case
Driver's side window switch
AC Compressor
Front Driveshaft
Is the radiator still good in this jeep? What about steering wheel and maybe cruise control system?
Sent from my XT1565 using Tapatalk
Radiator is probably junk...still has Chrysler tags on it soo.
Steering wheel is in good shape, although I have had the worst luck with pullers. HAve all the cruise bs too on hand.
Ok on radiator. The wrap on new jeep is all messed up and would like to stick with factory wheel over a new cover. How much you want for it? Could even do whole column if it's easier. Depending on price.
