thomasn456
- Auburn WA
I have a 1998 xj sport with a 4.0, aw4, Dana 30, chrysler 8.25
(JUST PURCHASED 2 WEEKS AGO)
Wife was driving the cherokee, it stalled, all gaugues dropped to zero, no power (gas pedal went to floor), pulled over, shut cherokee off then it wouldn't start back up again.
We replaced the cap & rotor, rotor was badly worn on one side so we replaced the magnetic pickup in the distributor along with the cap and rotor. The plugs were also recently changed. Disconnected the battery then reconnected the battery.
Started the jeep, gauges worked, idled for about 10 minutes, everything seemed fine. Went to pull out of the driveway and the same thing happened. Gauges dropped to zero, it died
Next day looking on this site for an answer, came up with crank positioning sensor/ CPK replaced that,
pulled out of the driveway, same thing happened. gauges dropped to zero, it died.
Turning the ignition to on now there is no gauge response, but it is getting fuel. But no spark
We checked all the fuses in the entire rig, fusable links, checked condition of all the relays, looked at all the grounds, all seemed clean and making good contact.
Any help would be appreciated.
Thanks in advance
Thanks in advance
