Thought I'd do a quick update on the progress on the XJ.
Most recent modifications and repairs included a new alternator and battery which made a most inconvenient exit while at Pismo Beach. Again, a big THANK YOU to Derek and Kyle from the JeepForum for running Ronie and I around to get parts then helping with R&R in the campground. A special "shout out" to JeepCherokeeBoy99 (aka PismoXJ99) from
who happened to be working that night and got us started on the right track then came by later to check on progress before heading home.
After running the dunes a bit for a couple of days, I found the steering wheel a bit off center again. Afraid this might have been more than just a need for a realignment, I purchased the C-Rok inner and outer steering box reinforcement plates. Between those and the Warrior Products steering box brace I do not think I'll be worrying about that area again.
Also in my pile of pieces is the Go-fer-it for flipping the driver side tie rod and a v8WJ pitman arm. That will get the tie rod on top of the driver side knuckle for clearance and the pitman arm is about a 1" drop from stock. With the v8WJ, the "bump steer" is said to be minimal to nonexistent so I'll let you know how it works out for me.
After that, I'm going to replace the remainder of the "block off" screws on my running gear and install grease zirks … then spend the remainder of the afternoon greasing them all. GEEZ, there are a bunch!
Well, that ought to keep me out of trouble for a few days anyway. I do have some plans for getting the spare tire inside while still having room for all the trail gear. Between that and taking care of the floor rust discovered a few weeks ago and the headliner that now touches my head, my summer is about set for Cherokee related doings … short the trails and camping of course.
The higher dollar updates and modifications I want to get accomplished (re-gearing, rock rails and frame stiffening) will need to wait until my budget catches up.
