Over the last couple of weeks there has been a whole lot of prepping, waiting and not a lot to show but, at last, there is something of some significance.
1 - Prepped the track bar mount, control arm drop bracket reinforcement and rear shock mount (cut for relocation) for welding.
2 - Did some fender liner and sheet metal trimming. Removed the front valance.
3 - Found a hole (no idea when or how it got there) in the vacuum bottle located behind the passenger side of the front fender … no wonder the speed control barely worked and the heater operated funky.
Welded the track bar reinforcement in place. Cleaned up and painted.
Not so much luck welding the CADB reinforcement. Turns out the welder is too small. Cleaned up area and repainted. Needs to have something before going off-road … I have another idea I'll share later after it is designed and installed. Didn't try to weld the shock mount for the same reason.
Fender trimming turned out well. Should take care of things until I decide if off-roading the Cherokee is going to get more serious.
Replaced the vacuum bottle.
Also remeasured the rear DL angle … with the 6* shim in place, there is still a 6* difference between the pinion and output shaft. Going to drive a bit without the rear DS to see if there is any change in the vibrations at speed or whether I'm feeling the tires. Will update after the evaluation.
Here are some pics of the completed fender/liner trimming --
