jeeptorino68
- Lebanon OR
it was slightly intermittent at first, as in it would engage and then disengage and then re engage, i thought it was the multi function switch (turn signal stick) and i replaced that with no benefit. i also tried a used brake light switch, and have tried a replacement vacuum servo.
i have no vacuum leaks
i ran accross this in the FSM:
NO CRUISE CONTROL WHEN SET BUTTON IS PRESSED & RELEASED
Check for: blown fuse, no vacuum at servo and/or defective
servo, disconnected speed control cable, brakelight switch out of
adjustment, faulty electrical circuit, faulty Park/Neutral switch
input to PCM, faulty PCM.
anyone have any other ideas?
i have tried adjusting my NSS after i cleaned it, it will start in park or neutral, but the reverse lights never come on. well almost never they sometimes very rarely will turn on.
any ideas?
i really need the cruise working. well i dont need it. but it would sure make it alot better
any ideas?
