1990 XJ Auto Transmission with 242 T-Case and cross member
thanasi85
Sacramento, CA
Took this setup out of a running 1990 XJ Limited 4.0L parts rig I purchased. Jeep was stock and had been rolled. Jeep was still drivable and I drove it home over an hour and had no issues with shifting and I also used the 4x4 and had no issues. Had 154,000 miles on it when pulled. Trans/T-case and cross member are all still bolted together. I pulled the crank position sensor and NSF off it and ended up cutting the speedo cable running from the transfer case to the gauge cluster but other than that is all there and ready for install. Since I pulled it, it has been siting in my garage out of the elements. Located in Sacramento
$160 obo takes the whole set up
Call or text Thomas
(916) 628-3598
Text sent
