gw204
- St. Leonard, MD
I posted this once and only got two responses. I've dropped the price and am posting again. I think this is a good deal.
1988 Jeep Cherokee Pioneer, Olympic Edition (whatever that means) - 99% stock
4.0 liter that runs good, AW4 that shifts smooth, NP231, D30 front (open) , D35 rear(open) - this was my daily driver
213,000 miles
No leaks that I know of
Power steering
Power brakes
AM/FM radio (original unit)
Dark blue exterior w/ little clear coat remaining, body is good and straight.
Dark blue interior, cloth seats in excellent condition, just needs a light cleaning
5 spoke aluminun wheels in descent shape w/ P21575R15 Kirkland All-Terrian radials in descent shape
A/C which I am going to have recharged soon
New 100 Amp alternator and I performed the charging system upgrades
New CCV lines, valve cover was cleaned and reinstalled w/ RTV and cork gasket - no blowby
New front trac bar
New T-Stat, coolant and heater hoses, coolant bottle
New exhaust
New oil pressure sender - guages reads approx. 20 at idle and 48 on highway once she gets up to operating temp.
I also have a set of springs and shackles from a '98 XJ that I was preparing to install w/ a new budget boost. The leafs were completely disassembled, sanded as smooth as I could get them, primed w/ Rustoleum and then painted w/ gloss black Rustoleum. They still need to be lubricated, assembled and installed. The BB is a 2" full length AAL from Rusty's and 1.75" coil spacers from RE. I've gots LOTS of time in the preparation of the leafs!
Now for what it could use/needs:
Fluids changed in the trans, t-case and diffs. It's been awhile....
Possibly a radiator. The band that wraps around the rad. snapped and as a result of resting against the rad, wore a small hole in it. It's currenlty patched w/ JB Weld and seems to be holding fine.
Light bulb in the climate control panel.
Rear hatch panel needs to be reattached. All the mounts were broken so I removed the panel, ground off what was left of the mounts and never got around to making spacers and putting it back on.
TB should probably be cleaned.
I would really rather not have to sell this but I can't come up w/ a good enough reason to keep her. The ol' gal would make an excellent building platform. The only thing I ask, is that if the new owner does build her up....please send me pictures!
I WILL NOT part her out so please don't ask. I'd rather have the additional monthly expenses of keeping her than cut her up.
Oh, the driver and pass side manual mirrors no longer adjust and it has a cracked lens in the pass side headlight that I just noticed. I'll fix the headlight if someone wants this Jeep.
Give me $1250 and I'll change the trans fluid and filter, t-case fluid and diff fluids before you pick it up as well as fix the headlight.
I'm open to offers but honestly, if I can't get close to $1250 for it, I'll will more than likely donate it and sell the BB separately. You guys don't want that to happen, do you? I could write it off for over $3K, but I need the cash now to get a T-Top put on my fishing boat.
Brian
213,000 miles
Power steering
Power brakes
New front trac bar
New exhaust
Brian
