89cherokeexj
- Victorville
My sis is looking to get rid of her jeep. It is a 1988 Jeep Cherokee 4x4, 4.0l, Automatic trans. The Jeep is almost immaculant inside, my sister takes very good care of her vehicle. The body is not perfect but pretty clean for the year (white in color). It has newer 31x10.5 tires on it. The rear axle is a Dana 35 3.55, and the front is a HP non disco Dana 30 with 3.55 gears. The jeep was hit on the driver side, the lower control arm mount is bent. The jeep drives fine, weve never had a problem with it. If you wanted to lift it I'd suggest long arms or replacing the mount. LIKE I SAID IT HAS NOT CAUSE USED ANY ISSUES. The jeep has tons of new parts including water pump, thermostat, hoses, bottle, tune-up and some other misc things. The jeep has the typical exhaust leak at the manifold. The miles are around 150k, Ill have to get actual mileage from her. She wants 1800 for it, and is somewhat negotiable on the price. Thanks JOSH
