box_goblin
- Seattle, WA
I had very similar issues, and it was the cable from the Coil to the Dist-Cap that was the culprit -- the connector to the wire inside the boot was not tight, so it would work every now and then. It puzzled me for a long time because every time I pulled a spark plug out to test it, it worked... Not saying that's the case here, but it is one of the quickest and easiest things to check; and for me it was easy to overlook. I'd recommend swapping a cable from one of the plugs to the coil-cap and see if you then get a clean, strong start.
