$100 -'99 8.25 drum to drum NEED GONE!!
DanMan2k06
Damascus, MD
Just like the title states. Complete 8.25 axle, drum to drum including the u bolts and brake lines. No e-brake cables. NO LEAKS. No noise. I need this gone by MONDAY or I will recycle and take what little cash they give me.
NEW (less than 500 miles):
-drums
-wheel cylinders
RECENT (within the year?)
-hardware, cables, adjusters
-shoes
I've got a plethora of brand new hardware parts and springs in the basement, I'll put on whatever I can (mixed d44, 8.25, and d35 hardware). Finally swapped in my built 44 so this needs to go ASAP! I will drain it, re-seal the cover, and let you fill it up with gear oil of choise.
Texts only! 240-750-0264. I cannot hold this past the weekend. Located in Damascus, MD 20882
don't junk it. If you still have it after the weekend lemme know i may take it for the braker hardware if nothing else.
Just picked up some brand new shoes from advance auto. Exchanged some two year old odds and ends and put the credit towards shoes.
Now the shoes, wheel cylinders, and drums are all new. Someone take this joker.
what's the ratio on it? 29 spline right?
Yup 29 spline, 3.55 ration, came out of a '99. This would be the perfect axle to swap your rig while you build your other 8.25, or in my case I dumped my noisy grinding D35 for this while I was building up my 44.
I just moved it back to work and have it stored in the basement, so my timeframe has been lengthened a little more. But I would MUCH rather someone on here grab it then get $40 (or less) from a recycler.
Tim if you work out payment with him he can drop it off at my work in Olney and you can pick it up from my house that night when i get home.
