1 HP 44 and 1 waggy 44
Mr.OverKill
i have access to one of each of these front axles, i can get the bronco front and rear axles and the waggy front and rear pair as well ( waggy has amc 20 rear ) ( bronco has a 9" rear ) i can pull them for cost plus $50 each for the fronts and an extra $30 for each of the rear's, the HP 44 has the cast radius arm mounts but that is easy enough to get around.
let me know and i will pull these and get them to you this week
:peace:
i fixed it
So that would make a front and rear axle combo right?? How much are the axles going to cost me, let me know I'm interested!!
Never mind I read it again, that is s set of rear axles, sorry about that.
no, the ford front HP44 and the 9"rear end, and the waggy dana 44 front and an amc 20 rearend, the cost was for the front axles only but for an extra $30 i will pull the rear axles as well, i need to check the cost of the axles from the owner and i will get back to you with a total for the sets, waggy front and rear and the bronco front and rear
Oh ok, so it is a set, one axle for the front and one axle for the rear. Yah let me now a price on them. These are full size axles, correct??
correct
