dieselenthusiast
- Zuni Mountains, New Mexico
I'm looking to replace my precats because they are 11 years old, probably pretty clogged and they produce enough heat in the summer that they cause vapor lock and cylinder miss-fires. Which is apparently a common problem even on stock 4.0s.
If the pre-cats flow as well as people say they do, then how could it cause vapor lock and cylinder miss-fires? I’m not calling into question your judgment; however, I’m just trying to figure out the 4.0L a little better. I understand how a diesel works much better than I know how a gasoline engine works. With a diesel, it’s all about reducing the EGT’s. A better flowing exhaust means lowering EGT’s and engine temps.
