Stang5lgt
- Parker, CO
So I been wanting to build a bumper for over a year now. Finally got a idea how to do it. I made a jig from plywood I can use as a model to get ideas and is cheaper then steel. I still have a little work to do on it. And some of the extra stuff you see is for strength to keep it straight. Once I am ready to build the steel one I have just cut pieces to match lay it on the jig model and tack weld it. I just need to figure out a way to keep the plywood from burning. Does anyone know if I coat it with fiberglass that will make it fire resistant?
