tcm glx
NAXJA Member #1033
- Riverside California
Any install tips for the TNT LA kit would be greatly appreciated, will be installing LA kit this weekend.......
beakie said:from what I have heard its a total waste of money and re-selling it for no more than $200 shipped is the best tip I have heard.
I would think the usual PB Blaster of everything that will be touched is a good idea. I thought I saw an install on here once before tho, atleast once.
Good luck with the install, and feed back on how it works, I would like to make this upgrade next summer if the house n wedding n honey moon budget allows it.
I am assuming he was kidding...JNickel101 said:WOW, are you kidding? Never heard anything bad about the TNT kit....
Gasman said:Use a Unibit to drill the holes in the unibody rail. Well worth the $30 or so cost of the bit. I did not need a right angle drill. Take measurements 3 times before drilling. Mount and tighten the control arms on the belly pan before you hoist it up into place. Once the pan is mounted, you don't have room to get the bolts in for the control arms. If you are not using the
TNT unibody protectors, you will need to shorten the sleeves by 3/16". The belly pan is heavy so having a friend around is helpful.
tcm glx said:I am assuming he was kidding...
do you have any clear shots of where all the bolts go threw the unibody cause i'm about to build some sliders for my jeep and i plan on getting the tnt y-link kit in the future and don't want the sliders mounting points to be in the way thanksGasman said:Here's a couple I had handy:
mustangconv85 said:do you have any clear shots of where all the bolts go threw the unibody cause i'm about to build some sliders for my jeep and i plan on getting the tnt y-link kit in the future and don't want the sliders mounting points to be in the way thanks
