Old October 9th, 2018, 19:33
RCP Phx RCP Phx is offline
Tera 2 Low kit with a wide chain
Got started today and was doing good till I realized the sycro hub has needle bearings in it. Got that done and mainshaft re-assembled, the new fork pads installed, the new selector shaft installed along with the shifter rail. Now it's time to clean up the covers to get ready to re-install.
Old October 9th, 2018, 20:09
Re: Tera 2 Low kit with a wide chain
I forgot a pic of the kit parts.......
Old October 10th, 2018, 20:33
I started cleaning today, it's got a good crust from leaking the past 10yrs. I'm soaking it tonight and will finish tomorrow while still waiting on some seals.
Old October 12th, 2018, 18:32
RedBirdStation RedBirdStation is offline
I just finished my install tonight. Got it backed out of the garage and test drove it and went through the gears. I still need to work on adjusting the Boostwerks shifter linkage but I believe I am going to like this modification.
Old October 12th, 2018, 20:03
Did you do both the 2 low and the chain? My day was 1 step forward 2 back, plus most of the parts were the wrong ones. I was hoping to get it done this weekend !
Old October 13th, 2018, 10:16
I got the seal in the tail cone and studded the rear cover last night. I'm waiting for my replacement studs for the front half case as we speak!
Old October 13th, 2018, 20:00
ehall's Avatar
ehall ehall is offline
why studs?
my '91 beater rebuild
Old October 13th, 2018, 20:05
I stud everything that I can, there's way to many benefits. I did receive my order and got the front case done and will start tomorrow after the Loctite's cured!
Old October 14th, 2018, 16:48
I got most everything done today, the studs made it easy!
Like I said, I don't like leaks...
Mains...
Oil pan...
Valve train...
and the trans...
Old October 14th, 2018, 19:36
I did the 2 Low and installed all new bearings and seals along with a new stock chain.
This thing rocks, drove around about 1 hour today and only needed to go to 4 low once to get over a hill. Think it will really come in handy since most of the time I run 2 Hi on most trails if its dry out. I shifts from 4 Low to 2 Low and unlocks the front locker in a second after shifting for those tight turns.
Old October 15th, 2018, 14:11
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
I just returned from a 1000 mile trip, with approx 450 miles being off-road and I was in 4WD very little. Installing a Tera 2Low when I rebuilt my t-case a few years ago was a good decision.
Speak the Truth-Question with Boldness-Speak without fear.
Old October 15th, 2018, 15:24
GreenMachine1 GreenMachine1 is offline
RCP Phx,
Looking good! Is that another stroker build for the second jeep or pictures from the previous build? Have any specs on all the studs? All from ARP? Keep up the good work and tech!
Old October 15th, 2018, 15:54
Originally Posted by GreenMachine1 View Post
RCP Phx,
If it's available it's from ARP, the rest are grade 10.9 stainless.
Old October 17th, 2018, 07:48
I want to say that I've been using "application" specific sealers lately, along with clean dry parts and letting it sit for a couple days to cure. In this case and my trans I used this.....
https://www.permatex.com/products/ga...-gasket-maker/
Old October 17th, 2018, 12:09
Groot99 Groot99 is offline
Studs for the tins is a great idea!!
Rebuilt NP231 HD, 6 pinion, wide chain, Tera 2Low, JB SYE hot_rod_hooligans MWC For Sale/Wanted Forum 8 April 26th, 2013 10:16
WTB: NP231 Wide Chain Kit djblade311 SoCal For Sale 3 October 7th, 2011 10:23
Wide chain kit... just curious. Mr. mud Modified Tech Discussion 7 April 8th, 2010 01:32
NP231 wide chain kit NIB! BillR For Sale: Private Party Only. XJ ITEMS ONLY 4 May 27th, 2006 18:52
231 Wide drive chain Boatwrench OEM Tech Discussion 2 March 15th, 2006 20:02
