24 HOUR JUNE ROTM TIE BREAKER
VOTE
  • robz95xj
    Votes: 23 56.1%
  • xjeeper
    Votes: 18 43.9%
  • Total voters
    41
  • Poll closed .
XJLI
Long Island, NY
24 HOUR TIE BREAKER!!!!
ROBZ95Xj
1995 Jeep Cherokee Sport
4.0 AX15 4.3 Atlas
Frt supention
3link
4.5" RK Coils
extra coil isolators for total of 5.5"
Bilstien 5100's
Rear suspention
5" DPG leafs
shackle relocation boxes
.75" Rustys shackles
.5" lift blocks
total 5.5"
daystar prgressive bumpstops
BBCS shocks
87 Ford F350 hp60
5.38's lockrite
10 factory shafts
poly performance drive flanges
Ried Knuckles
Balistin hi steer arms
RS Cover
Rear Axle
92 Ford E350 D60 ISU
Yukon 35 Spline Shafts
5.38's
Spool RS Cover/Disc Brackets/Simple swap kit
42" Pitbull Rockers
Hybrid Cage
Custom bumpers and rockers
Belly Pan
Tractionbar
Battery Relocated behind pass seat
summit 16 gallon fuel cell
XJEEPER
2000 Jeep Cherokee Sport
Under Hood
4.0L Motor
Fastman 62mm throttle body
Flowmaster Muffler w/hi-flow Cat
AEM Dryflow filter on custom intake tube
Optima Red Top battery
Viair 450 Air Compressor on custom bracket
AW-4 Tranny with Shift Kit
231 T-Case w/32 spline shaft
Tom Wood’s Custom Driveshafts SYE
Woody’s Front/Rear HD Driveshafts
Drivetrain
HP D30 with ARB air locker-30 spline
30 spline Alloy USA axle shafts
Alloy USA tube seals
Rotated and gusseted housing inner C’s
T&T Customs weld-on Truss
Custom LCA Skids
Custom Upper and Lower shock mounts
Custom Trackbar w/JKS axle bracket
Custom trackbar truss/crossmember
Ruffstuff HD diff cover
WJ brake swap with Akebono calipers
Custom 1.25” DOM steering linkage w/Tera TRE’s
Currie Anti-Rock sway bar with custom brackets
Prothane coil insert bumpstops
SS Long-travel brake lines
XJ D44 Rear with ARB air locker-33 spline
33 spline Alloy USA axle shafts
4:88 gearing
TJ Rear Disc brakes
Ruffstuff HD cover
Extended Bumpstops
Raised shock mounts
1.25” Billet Wheel Adapters
285/75/16 Maxxis Bighorn tires mounted on Jeep Moab wheels
Suspension and Chassis
T & T Customs Y-Link Arms and Crossmember
RE 5.5” Coils with .75 poly spacer
RE 1463 Leaf packs 3.5”
2” Custom anti-wrap spring perches
1” Custom boomerang shackle
Bilstein 5165 Front / 5150 Rear Shocks
T&T Customs weld-on Unibody Stiffeners
Temper Mental Racing reinforcement plates
JKS SBS plating-both sides
Armor
Custom Tube Front Bumper-1.5” DOM
Custom Rock Sliders 1.5” DOM
Custom 1.75" DOM Tube rear bumper -in progress
JCR Rear Qtr Guards-in progress
Miscellaneous
Bushwacker Flat Flares-painted to match body
Hella H4 headlights w/upgraded harness
Front Door storage pockets
Custom rear passenger seat headrests (ZJ)
Custom ARB plumbing with manual pneumatic switches
2 Gal Air storage tank
Uniden CB w/ Wilson 1000 roof mt. antenna
Fire ext , 1st Aid kit
Recovery straps , clevis, tire plugs, HiLift jack, LoLift Jack
