Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old May 18th, 2005, 11:51
CRASH's Avatar
CRASH CRASH is offline
Welcome
Welcome to the new fabrication area of . This forum, for the moment, is open to members, only. We are developing this forum and tailoring it to the needs and desires of the membership. As such, we are going to use an adaptive management approach in moving threads around for a while. Some current and past threads will be copied from ModTech to sort of "seed" this forum.
I think we can all agree that a fabrication forum is sorely needed, as there is a definate dichotomy of postings in ModTech. My personal goal for this forum is to help push the boundaries of XJ modification. We have a very knowledgable and capable group of fabricators on this forum, and I'm hoping they will share their design ideas here.
As for ModTech, I want it to remain a good forum for answering questions regarding bolt-on products, etc. I hope the knowledgable among us will continue to freqent Modtech and help as time and desire allow.
CRASH
Old May 18th, 2005, 11:53
Lawn Cher''s Avatar
Lawn Cher' Lawn Cher' is offline
Re: Welcome
Thanks, happy to be here.
Old May 18th, 2005, 12:08
Goatman's Avatar
Goatman Goatman is offline
Re: Welcome
What backspacing do I need to run 42's with 5" of lift?
Good to have this thing going. Thanks to all the members who supported the idea.
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old May 18th, 2005, 12:24
Jes's Avatar
Jes Jes is offline
www.urfracing.com
Re: Welcome
Nice addition.
Question, would a thread like this http://www.naxja.org/forum/showthread.php?t=3156 go in Mod Tech, here, or in the Paint Bodywork forum?
Old May 18th, 2005, 12:28
Glenn B's Avatar
Glenn B Glenn B is offline
Admin and Member #69
Re: Welcome
No doubt will eventually end up in the bodywork area..... after all of the trapped dirt and moisture ends up rusting all of the sheet metal out behind the new tin.
Originally Posted by Jes
Nice addition.
2001 4door XJ. 4.5 inch long arms, 33x12.50-15 Mickey Thompson Baja MTZ's, Superchips Flashpaq, bigger throttle body, AFE cold air intake, Advanced Adapters SYE, and a ton of stuff still to do on this project!
Old May 18th, 2005, 12:29
CRASH's Avatar
Re: Welcome
Nice addition.
I'd put that in bodywork. You didn't buy it, you made it.
Alternately, you could shove it in "Poseur Tech". Coming soon to a mall near you.
CRASH
Old May 18th, 2005, 12:41
Jes's Avatar
Jes Jes is offline
www.urfracing.com
Re: Welcome
CRASH
Here's the first topic for "poseur Tech", the TireFly Bilstein mod...
Old May 18th, 2005, 12:45
Ramsey's Avatar
Ramsey Ramsey is offline
Re: Welcome
Awesome, now i can finally learn something other than how many plumbing parts are needed to make a good lift
Old May 18th, 2005, 13:09
BrettM's Avatar
BrettM BrettM is offline
Re: Welcome
hmm, looks like CRASH got the hydro assist hooked up, how is it?
Old May 18th, 2005, 13:45
CRASH's Avatar
Re: Welcome
Sucks on the road. Writeup with a fix on the way. Super secret tractor parts are going to be utilized to isolate the cylinder for highway use.
Lots of power, too much in fact. I need to move more volume though, as the cylinder lags a bit behind the gear. Also, I'm having a weird issue when the engine (pump) is warm. I get no assist at idle when it's warm (it's fine cold). Bring the idle up to 900 or so, and the assist comes back. Again, it may be a volume thing.
Hmmmmm.....maybe I should start an actual thread!
CRASH
Old May 18th, 2005, 14:47
BrettM's Avatar
Re: Welcome
very interesting, please do start a thread, mine works great on the road...
Old May 18th, 2005, 15:05
Jes's Avatar
Jes Jes is offline
www.urfracing.com
Re: Welcome
Sucks on the road.
That's an understatement.
I almost wrecked your junk ten times driving to the grocery store!
Old May 18th, 2005, 16:18
JeepFreak21's Avatar
JeepFreak21 JeepFreak21 is offline
Re: Welcome
Yeah, but what were you getting at the grocery store? More beer perhaps?
Billy
Old May 18th, 2005, 17:46
Lincoln Lincoln is offline
NAXJA Member #321
Re: Welcome
Isn't that kind of like adding a fuzzy cover to a toilet?
Old May 18th, 2005, 18:15
rock rash's Avatar
rock rash rock rash is offline
Re: Welcome
Thanks for starting this. it was a great idea!
Rate This Thread:
