Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Sierra Chapter
Sierra Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
  #16
Old July 9th, 2014, 20:20
CAJJ93XJ CAJJ93XJ is offline
Re: Vanilla Gorrilla blog
if you wear them out that fast, may be time to consider http://www.genright.com/ProductInfo....0#.U74GUjzn-P8
Old July 9th, 2014, 21:57
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Yeah I was looking at those but I would have to modify my re arms to work. They are a wider joint than stock bushings. Re makes a retrofit kit and uses their newer bushings. I would just need to tack the sleeves in the axle mounts then squeeze in the bushings and sleeves. Currie also makes a Johnny joint retrofit but supposedly it's only for the drivers side.
I wonder if poly joints would be an option?
Metal cloak is working on a retrofit for their bushing/joints but it's not ready yet I guess.
Old July 12th, 2014, 19:04
Rob D's Avatar
Rob D Rob D is offline
Originally Posted by GordoSmasho View Post
Thanks haha.
So what is everyone with stock ish axles doing for upper axle control arm bushings? Poly, rubber, joint. I have stock mounts on the axle and destroyed the bushings I put in last year in just a handful of runs. They were rubber. I have been looking at a few other options.
If you want cheep, I'm pretty sure I have some stockers for the axle end. I think they are TRW's, but??? Anyway, they're yours if ya want em.
Rob D
'91 Cherokee Larado, BDS 5.5" coils w/ACOS's, 6.5" Clayton springs, 37" Patagonia MT's, 4:88's, 35-spline D44 w/ARB and Explorer disc's in back and a narrowed hp44 front w/E-Locker.
Old July 12th, 2014, 20:01
Heck ya I'll take them rob. I'll give you a call Monday and swing by.
Old July 13th, 2014, 08:22
Rob D's Avatar
Sent ya a pm. They are TRW's and I have 4 of them. That should hold you over 'til you get that 70 done.
Rob D
Old July 13th, 2014, 19:07
Hell yeah. I got your number already rob. Not that I'm stocking you or anything.
Just trying to make things weird...
Old July 14th, 2014, 23:25
Big thanks to rob for hooking me up with some upper bushings. Thanks mang. Good talking to ya.
So I set my first pattern on the dana 30 tonight. Need some insight. It looks to me like the pinion is either a hair to deep or too shallow. The thing is if it's too deep I have no shims in it right now. Just the baffle is behind the inner race so what do I do if that's the case. Pull the baffle?
Backlash is at .09
Here are the pics.
Drive
Coast
Old July 15th, 2014, 07:40
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
Shoot it looks good right there. I'm tempted to say its good. That pattern does look a tiny bit shallow. Its a little more to the toe side of the ring gear which means you will end up increasing backlash a bit. At that point you will probably end up putting shims under the pinion to increase pinion depth since it will be way too shallow and I wouldn't want to run more than 9 -10 thousandths up front anyway so I would want to bring it in. which will bring bl in some more . Is the setup race for the inner pinion bearing seated all the way in? Pinion nut torqued down right? Bearing caps on? I always use this write up :http://www.pirate4x4.com/articles/te...sta/Gear_Setup
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Old July 15th, 2014, 10:34
How much deeper do you think I should go with the pinion Jon? Yeah everything is torqued down.
By the way. Best tool I've purchased yet.
Old July 15th, 2014, 11:07
its tough to say since I think that pattern looks pretty good where its at. Its more like, it could always be better, but it looks good there. I have no idea what I am talking about really, but it looks like if it was my gear setup I would increase BL by 1-2 thousandths. Then check pinion depth and go from there.
Old July 15th, 2014, 12:03
That's what I was thinking. I'll try that tonight.
Old July 15th, 2014, 12:53
keep a note of the shim stacks and you can always go back to this setup if its the best you can get. 9 thousandths BL is good and the pinion depth is probably OK to run. But once you open up BL a few thousandths then you will be able to probably bring the pinion in a few thousandths and that will possibly get you to a point where you can dial in BL and pinion depth.
I can tell you that when I was doing my gears, even when I thought it was perfect, I put final bearings back on and had to reset BL and pinion depth which sucks. if you are not using setup bearings then you will be fine.
Old July 15th, 2014, 13:45
I am not using setup bearings. With that clamshell puller kit it's a breaze to swap shims.
Old July 15th, 2014, 19:36
So here is the second pattern. Backlash is at .05.
Drive
Coast
What do you think?
Old July 15th, 2014, 19:38
Pinion bearing preload with new bearings is between 20-40inch/pounds right. I'm at about 35. Seems really tight but this is my first time.
Rate This Thread:
The alien blog frontman Sierra Chapter 16 April 29th, 2012 16:09
Blog RescueGreenXJ Non-Tech / Off Topic 2 December 16th, 2011 11:24
Blog fun... 5-90 Non-Tech / Off Topic 0 November 14th, 2010 20:58
Vanilla Ice and MC Hammer .. together at last. urban yan Non-Tech / Off Topic 4 February 13th, 2009 12:43
Vanilla Pudding Robbery bjoehandley Non-Tech / Off Topic 3 June 5th, 2007 20:49
