Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
  #421
Old November 26th, 2011, 16:09
ROBZ95Xj's Avatar
ROBZ95Xj ROBZ95Xj is offline
Re: The Stupidist Jeep on the Planet
spent a large chunk of the morning cleaning up the garage as it was a mess and it was a hard time walking around without steping on stuff, also decided to install the traction bar, but there was 2 little issues, ifrst was when it was origanally welded up the 2 eye holes shifted making it impossib;e to reinstall, and 2nd when i installed the shackle relocation brackets that tilted the axle up, so i cut the top bar off and repositioned it, now tractionbar is in for good fuel system just might wait as im knocking out alot of the little things
Old November 26th, 2011, 17:26
MoparManiac's Avatar
MoparManiac MoparManiac is offline
Lookin good dude!
Old November 26th, 2011, 20:49
5-Speed XJ 5-Speed XJ is offline
this thing has come along way from back when I was following the build on ENH to now on it still amazes me
Old November 29th, 2011, 20:38
ROBZ95Xj's Avatar
steering done and in
Old November 30th, 2011, 08:38
ktm racer 419 ktm racer 419 is offline
ZOMG NO SAFETY WASHERZ!?
Old November 30th, 2011, 10:15
ROBZ95Xj's Avatar
Ruffstuff high misc spacer/safty washer combo ya newb
Old November 30th, 2011, 14:53
cmelo cmelo is offline
Sweet, looks done. Come pick me up in it and take me out on a date.
Old December 2nd, 2011, 20:11
ROBZ95Xj's Avatar
smashed out the exhaust today, its a downpipe from advanced auto, hi flow cat and cherry bomb turbo muffler, and a bunch of misc pieces and bends
flex pipe right in frt of crossmember
cat
muffler
Old December 4th, 2011, 20:49
ROBZ95Xj's Avatar
fuel system is done, just gotta get gas after work tomorow and check for leaks
Old December 5th, 2011, 19:15
5spd_xj's Avatar
5spd_xj 5spd_xj is offline
<<the good ol days
Lookin FANCY!
Old December 5th, 2011, 19:18
ROBZ95Xj's Avatar
Originally Posted by 5spd_xj View Post
Lookin FANCY!
so fancy that one of the an fittings leaks out the threads so i tossed some quick steel on it and hope for the best
Old December 7th, 2011, 06:53
WAD357 WAD357 is offline
Almost there man!
Old December 10th, 2011, 15:18
shiftier boot shock covers look sweet
Old January 3rd, 2012, 22:44
ROBZ95Xj's Avatar
UPDATES!
for starters my turning radius sucked, the tj pitman arm i had simply didnt have enough throw, so i got a WJ arm from Jeff at Crown, the issue with wj arms is the master splines are clocked diffrently then a xj/tj arm, so i took a file to it and now have unlimited clocking and full throw steering
i also had issues with my limiting strap setup, i was gonna run ep eye to eye on the shocks, i got 29" straps, my shocks are 29.75 ext, i didnt know that straps stretch, so i redid the upper shock mount and dropped the mounting point for the shock 1.5"
strap is just starting to snug up as the coil is almost unseating(dont be hatin on meh "mad ghetto" ramps
the the good bit, spent the past few days fabbing up a rear bumper and crossmember. The crossmember is 3x3x3/16 angel welded to the frame and shackle boxes, im also gonna add 2 pieces of tube from the inner frame rail to the back of the crossmember for more support
the bumper is 2x5x2/16 box cut and bent, legs and quarter guards are 2x2x3/16 and is conected to the crossmember with 12 bolts, and has a flush mounter reciever that is part of the middle bumper mount
Old January 4th, 2012, 03:15
Nice Rob!
I like the bumper.
Rate This Thread:
Jeeps on Little Planet Pic 4WDlifeform Non-Tech / Off Topic 2 November 30th, 2011 18:36
Blowing Up a $60,000 S.U.V. To Save the Planet buzzbombxj Non-Tech / Off Topic 8 July 25th, 2008 07:19
Planet Audio 12 inch sub Feeler Skwerly SoCal For Sale 0 January 18th, 2008 13:13
Planet Audio Amplifier Opinion blaisetd Non-Tech / Off Topic 3 April 25th, 2007 12:08
The Northeast Association of 4WD Clubs Cleans our Planet for Earth Day! Kejtar Land Use Forum 0 March 21st, 2003 10:55
