Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Colorado Chapter > Other Rides and Builds
Other Rides and Builds A place for the discussion of Colorado "Side Projects"
  #46
Old August 20th, 2013, 19:36
eflores eflores is offline
Re: I really sold out this time
you're gonna need more cage too....for when you roll it
Old August 20th, 2013, 20:25
DutchVDub's Avatar
DutchVDub DutchVDub is offline
I'll just have to be extra careful wen crawling the mall.
This morning I got my Rampage cargo basket installed. I went with the Rampage for 2 reasons. 1) It was the cheapest one 2) It actually hinges up to allow better access to stuff underneath. Easy to install and should work well. My only issue is that the sub box is in the way of where the passenger side latch/rest bracket goes. I'm just running the one on the driver side and it stays latched fine, its also rattle free, so I'll see how it goes. Biggest thing I'm worried about is the sub box cracking from the weight once its loaded up, but besides my cooler the only thing going up there is clothing bags when we go camping. Everything else will fit underneath.
I also got the TNT Aluminum belly skid system installed. Again, for the most part the install was pretty easy. My only real complaint is the very rear mounting points for the fuel tank skid. They have you drill holes into the stock skid and then bolt the two together. The problem is there is a fair amount of space between the sides of the two skids, and the holes in the aluminum skid are way oversized for the hardware they give you. I had to get a bit creative back there with some old shock stem bushings and fender washers.
Here you can see the rubber bushing I placed between the two skids. The bolt was a 3/8 Grade 8 I had lying around. There is a washer and nylock nut on the other side of the stock steel skid.
And here is the big fender washer I had in a bin. I think its left over from an old VW, or maybe my 92 XJ. I'm not sure anymore. On the other side I didn't need the rubber bushing, but I did need the big fender washer.
Americans can sleep at night because US Soldiers stand ready to fight
Old August 20th, 2013, 20:44
adrenalinepirate's Avatar
adrenalinepirate adrenalinepirate is offline
Nice skids! Bumper and gears next?
Old August 20th, 2013, 20:53
DutchVDub's Avatar
Bumpers yes, gears no. I'm not going to change out the gears until I am ready to go to 37's. It drives well enough around town and with the 4:1 transfer case there won't be a problem off road.
Old August 20th, 2013, 22:30
time2getdirty's Avatar
time2getdirty time2getdirty is offline
my cats breath smells
http://www.colorado4x4.org/vbb/showt...der-body-Armor
Originally Posted by YELLAHEEP View Post
Probably gunna buy a JK.......
Old August 21st, 2013, 00:41
Makes sense Dutch. Oh snap a way to keep it pretty! Good eye David.
Old August 23rd, 2013, 10:33
dirteexj94 dirteexj94 is offline
Dutch if you ever want to ditch the Rubicon wheels let me know
Old August 23rd, 2013, 11:12
DutchVDub's Avatar
They're going with the XJ, the buyer is getting the needed adapters before he picks it up.
Old August 30th, 2013, 15:36
DutchVDub's Avatar
Finally got my JCR front bumper yesterday and installed it this morning. I also mounted up the winch from the XJ with a new MasterPull synthetic winch rope on it.
Old August 30th, 2013, 16:21
in4aride in4aride is offline
Looking good.
Old August 30th, 2013, 21:14
DutchVDub's Avatar
Thanks man, I also have a set of Artec trusses to maybe install this weekend. Depends on how motivated I get.
Old September 2nd, 2013, 20:05
DutchVDub's Avatar
Just got done running Spring Creek and Saxon Mountain Road. Now I am sitting at Tommy Knockers. Took awhile as we wound up linking up with another group that didn't have much experience. I guided them through all the stuff. Good guys though. There was a super clean 91 full size Blazer in their group on 35's that took awhile to get through the obstacles. I felt really bad when he slid off a rock and crunched his rocker.
Pics? Yeah..... I really suck at that.
The JK did great though. I am continually amazed at this thing. I definitely put the TNT aluminum skids to work but even when it hit on them she just pulled herself up and over. I think the best thing about that full belly system is the piece of mind it gives you. You hear a thud underneath and know there really isn't anything to worry about.
I will say some if the rock slide remnants on Saxon really give a pucker factor. I think the road is even bumpier now too.
Old September 2nd, 2013, 21:03
xj-grin xj-grin is offline
NAXJA Member #1096
do better on the pics for the Artec install -- I believe I will be picking one up for the Rubi front sitting in my garage before I throw it under the WJ...
Old September 2nd, 2013, 21:30
you really need to update your signature
Old September 2nd, 2013, 22:19
DutchVDub's Avatar
I did, maybe you need to update your eyes.
Rate This Thread:
Sold my XJ :( john_yarbrough SoCal Chapter 15 February 16th, 2011 19:59
They are sold out!!!!!!! mizzutgr Non-Tech / Off Topic 12 January 29th, 2011 23:24
sold xDUMPTRUCKx SoCal For Sale 6 September 10th, 2009 23:41
the car you never should have sold...... shortxjdoug Non-Tech / Off Topic 67 November 15th, 2006 00:43
