Old October 24th, 2006, 14:56
mikeny59 mikeny59 is offline
NAXJA Member #300
towing...
I've read that an xj can tow about 5k pounds. Dumb question probably, but with a trailer with a gvw of about 3k, I'm assuming all I can throw on the trailer is 2k?
thanks...
Old October 24th, 2006, 15:00
Rev Den Rev Den is offline
Re: towing...
MAX.
Rev
Old October 24th, 2006, 15:10
NAXJA Member #300
Re: towing...
Second imbecilic question, how much does onboard load weight impact the 5k figure?!?
Old October 24th, 2006, 17:41
xjtrailrider's Avatar
xjtrailrider xjtrailrider is offline
Re: towing...
I tow with my XJ's all the time, I can assure you that even with trailer brakes I wouldn't tow more than 3500# on the highway. The XJ's just don't have enough weight to safely handle more than that in a panic situation. The XJ does have the ability to move that much weight(5k) just not handle it.
Old October 24th, 2006, 18:34
NAXJA Member #300
Re: towing...
I bought this great trailer a few years ago, all aluminum, 5x8, so easy to push around, my eyes popped when I looked at the reggie. I use it locally for bikes and building materials.
My better half and I bought a small place in Fl., but we don't get too much time down there. I wanted to buy a bunch of Ikea stuff up here in NY and save what precious time we spend there doing anything but shopping for furniture. Hence the I95 trailer adventure.
Forget it. Just going to build/buy a decent roof rack, borrow from a friend one of those gear carriers that utilize the hitch, supposedly holds 500 lbs. or so, stuff the inside w/as much as we can, and call it a twenty-hour day.
Thanks for the heads up; not used to 80mph panic stops; still stuck in the past - NY max. 55mph...
Old October 24th, 2006, 20:31
Motornoggin's Avatar
Motornoggin Motornoggin is offline
Re: towing...
Your technically are supposed to subtract in vehicle cargo and passengers from the max tow rating.
Old October 26th, 2006, 14:21
NAXJA Member #300
Re: towing...
Not bumping thread but friend at work said the "WT/SEATS" on my NYS reg. that says 2990 is total weight of loaded trailer. If so, what's the weight of trailer alone?!?
Right now it's sitting under a tarp and a heckload of cca, before I tear into that mess, will there probably be a riveted plate w/some load specs?
BTW, it's a "Compliment" make, expensive compared to others of the same size but built like a tank...
Thanks,
Flat Towing/Dolly Towing/Lockers ? 2xtreme Modified Tech Discussion 17 August 24th, 2018 16:31
Towing joedurt1 OEM Tech Discussion 2 March 26th, 2004 07:56
Towing randrews Modified Tech Discussion 5 March 19th, 2004 21:25
a towing ? doaxj Modified Tech Discussion 1 January 2nd, 2004 16:12
Towing my XJ...what should I know first? Jump This OEM Tech Discussion 8 July 28th, 2003 12:51
