Old November 5th, 2007, 18:46
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
Box o' rocks
90 XJ 4L Laredo Auto, 3" w/full pack
Problem:
I drive to work every day down 8 miles of semi curvy road doing 40-50, then 5 miles flat country road doing 50-60. Then 5 miles of freeway at 60-70. Take the off ramp, stop, turn left, turn left again, accelerate to about 35 and then it happens. It sounds like grinding, binding, dragging.
Everything else is good, after driving 18 miles at a good clip, no stumbling, temps & pressures OK, all fluids clean and changed regularly. All steering components OK, axle u-joints OK.
When I go out on my break and take it around the block a couple times, it won't replicate, won't do it again. Then I drive home, everything OK until I get about 100 yds. from home and it does it again. It's been doing this for several days, and I can't find squat!!??
Any ideas????
Old November 5th, 2007, 20:18
Mopar It's Avatar
Mopar It Mopar It is offline
Re: Box o' rocks
that is WEIRD. but what exactly 'happens' you said grinding binding dragging.. how about when u shank those sharp left turns ur exhaust is loose and grinds up against the ol' driveshaft?
Old November 5th, 2007, 20:22
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Re: Box o' rocks
WOW this thread looks familiar!
Old November 5th, 2007, 20:53
ParadiseXJ's Avatar
Re: Box o' rocks
Uh, yeah, what happens is the question. I'm not "shanking a sharp left", I'm just turning left, onto a street, in a business district. When it does it's thing, it's speed specific (i.e. more faster = more rubbing).
Can't tell if it's coming from axle (brake rub or u-joint) or drivetrain (trans/engine/etc.).
Old November 6th, 2007, 08:48
ParadiseXJ's Avatar
Re: Box o' rocks
One bump
I think I've narrowed it down to a.) front driveshaft noise or b.) sticking caliper. Although I've greased the calipers up, there are wear grooves in the slide. Also, I could take the front shaft off to see if the noise still persists and look at the front diff.
Box o' Rocks ParadiseXJ Modified Tech Discussion 10 November 7th, 2007 12:31
Red Rocks....ROCKS!! riverfever Colorado Chapter 11 July 14th, 2006 19:46
Moon Rocks Funny Rocks hards91xj NorthWest Chapter 5 February 13th, 2005 13:22
UCP On the Rocks II Lynn North Atlantic Chapter 10 July 25th, 2003 20:59
