Go Back   NAXJA Forums -::- North American XJ Association > Vendor's Marketplace > Vendor's Specials
  #31
Old December 5th, 2017, 17:00
JonnyCat63 JonnyCat63 is offline
Re: ***New Product Announcement*** IRON ROCK OFF ROAD 3 LINK!
I ordered my 3 link from IRO during the Black Friday sale. If you want the 1/2" bolt option, just call them and order the 1/2" flex joint. That's what I did, and all you need to do is drill out the UCA to 1/2". Hopefully the whole kit is supposed to ship this week, can't wait for it to get here!
Old December 5th, 2017, 17:16
Skipper51's Avatar
Skipper51 Skipper51 is offline
I would have done that but nowhere did I see that option on the site. I am bummed! I also looked through all 14 or so pages on XJ's to see if I could find it but with no success.
Iron Rock Off Road you should put that as an option there on the long arm page.
2000 XJ, on 33's;
My we strive to leave every place we visit at least a little better than when we arrived.
Old December 5th, 2017, 17:25
need-a-bow's Avatar
need-a-bow need-a-bow is offline
Ahh gotcha. I was a bit confused by that. I thought it was a special option. I think I'll do that, or at least get a 1/2" ID bushing
Sent from my SM-G955U1 using Tapatalk
Old December 8th, 2017, 05:22
SlowXj SlowXj is offline
Does anyone know of a 9/16 bolt option? Just to add that little extra unnecessary beef....Lol
Old December 11th, 2017, 06:49
need-a-bow's Avatar
I know Currie and IRO make a 1/2" flex joint for the axle end. Personally Im going to use a JK D30 bushing as it uses M12 vs M10 bolts for the same price as the stock XJ VS $50 for a flex joint. I only drive on curbs anyways, so I dont need all the flecks.
Old January 17th, 2018, 13:37
JTProuhet JTProuhet is offline
I have a currie Johnny joint in my axle so i drilled the uca to 1/2". Really digging the kit besides the royal PITA it is to adjust the caster and having to drop the crossmember to get the UCA out of the crossmember. But how often do we actually do it? Was also a little head scratcher seeing there's only 4 carriage bolts holding the center section on the outer sections of the crossmember
I did have an issue with the uca making contact with the driveshaft yoke under full compression on driver side. IRO has handled it well and has been in contact with me on the issue. Following the directions for arm length and caster angle when u installed it. I think it had the pinion too high. Gave it some more caster, dropping the pinion down a bit.
Old April 14th, 2018, 22:16
Reviving an older topic... I'm fairly pleased with the rock link arms. With that being said has anyone installed the coil conversion they offer? I feel like that would make for a comfy trail ride lol
Sent from my SM-G900R4 using Tapatalk
Old April 15th, 2018, 11:20
Skipper51's Avatar
As long as this is reopened----- I need to adjust my caster as Les Schuab wouldn't do it or just didn't do it when i got my alignment. Do i need to remove or drop the cross member? Cant i just take it off the axle and twist it from there?
2000 XJ, on 33's;
Old April 15th, 2018, 12:30
two_door_rob two_door_rob is offline
I was not able to twist the upper link around to adjust it without removing, but the suspension was also not at full droop when I tried. I think it was mentioned earlier in this thread, if you don't want to remove the crossmember to get the upper link out, you can clearance the floors enough with a bfh to get the link out with the crossmember still installed.
Old April 15th, 2018, 13:42
Skipper51's Avatar
So I didnít need to remove the crossmember. What I did was jacked up the body on jackstands remove the front wheels, and let them sag as much as they could with my sway bar links disconnected. Then by removing the bolt at the body and the bolt at the axle I was able to twist it until I finally got the right length.
2000 XJ, on 33's;
Old March 20th, 2019, 08:44
93bluebeast's Avatar
93bluebeast 93bluebeast is offline
What size drill and tap do you youse for the 3rd cross member bolt? Seemed to have misplaced my instructions.
Old March 20th, 2019, 13:14
Skipper51's Avatar
Still loving mine.
Here is the installation instructions: https://www.ironrockoffroad.com/Merc...nk_Install.pdf
2000 XJ, on 33's;
Old March 22nd, 2019, 05:52
Awesome thank you
Old May 11th, 2019, 11:04
Digmaster88 Digmaster88 is offline
Location: Colquitt, Georgia and De Leon Springs, Florida
I have this kit on my xj. Currently on 37" swampers with full width tons using only a 4.5" lift. Good flex and driveability No issues so far just bought some decent 39.5x15 swampers so lets see what happens in the near future.
Old October 6th, 2019, 04:02
Again reviving an ancient thread... But if anyone has had issues with the upper arm making contact with the pinion I feel your pain. I went back and forth with Josh from iro about the issue and finally set caster to 8.5 degrees to abolish the issue. I had driveshaft vibs but I was accepting of that. I assume my low lift height (3.5) and small tires (31) made the up travel situation worse. Anyways on to the good stuff. Josh informed me they made an improvement to the upper arm design. This week I am going to send him my arm and he is to send me the updated one. Kinda bummed my Jeep will be down for a week and for paying for shipping the original arm to them but beggers can't be choosers...
Rate This Thread:
Iron Rock Off Road DavesOffroadSupply Vendor Advertisements 43 May 31st, 2013 05:49
Iron Rock Off Road DirtBound Offroad Vendor's Specials 0 November 27th, 2012 15:39
Iron rock off-road willsmysticcobra NAXJA Vendors Info and Feedback Forum 6 September 18th, 2011 22:07
