Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
  #331
Old June 8th, 2011, 07:41
MrSimon's Avatar
MrSimon MrSimon is offline
Re: The Stupidist Jeep on the Planet
Sweet progress!!!! Keep up the motivation and this thing will be on the trails sooner than you think.
Its gonna be awesome when its done.
Old June 8th, 2011, 20:29
ROBZ95Xj's Avatar
ROBZ95Xj ROBZ95Xj is offline
nothing real cool going on tonight, did get all pass side elec in the engine compartmemnt hooked up and starter installed, also drilled out the orfice in the ps pump to help with flow, as it probly wont have hydro assist at first, tomorow will be a shprt day at work so im hoping to get fuel rai in and all driver side elec done as well on jumping the nss, maybee get so me welding done
Old June 9th, 2011, 21:18
ROBZ95Xj's Avatar
got a solid bit knocked out tonight even with a late start
ps pump and box installed
fuel rail installed
all drivers side elec done(cept rear coolant sensor)
fenders and header panel installed
radiator and hoses installed
real coolant sensor replaced
all fluids topped off
im pretty excited to beable to start with final assembly of things, tomorow after work i hope to jump the nss and do a few other odds and ends and hopefully bring it back to life this weekend
Old June 10th, 2011, 02:35
5spd_xj's Avatar
5spd_xj 5spd_xj is offline
<<the good ol days
Very nice buddyboy!
Old June 19th, 2011, 19:43
ROBZ95Xj's Avatar
got the motor all put together and running but have been battleing it overheating at idle, swapped the tstat and its gotten better
my ghetto fuel system
i added a cooler for the power steering
painted the grill metallic charcol
will have a cool update tomorow
Old June 20th, 2011, 14:17
ROBZ95Xj's Avatar
got some cool stuff today, 5.38's install kits, spool for the rear, lock rite for the frt and wheel bearings for the frt
hopefully ill get the axles together sometime after nac fest
Old June 20th, 2011, 18:27
XJLI XJLI is offline
mmmmm purple
Old June 20th, 2011, 20:27
MoparManiac's Avatar
MoparManiac MoparManiac is offline
Nice, I love new parts
Old June 20th, 2011, 20:40
ROBZ95Xj's Avatar
i used to, i now like installed new parts better
Old June 30th, 2011, 09:03
ROBZ95Xj's Avatar
finally broke out the welder last night, tossed in a spool of flux as i was out of gas, made a filler piece for where i notched the cross member for the atlas, not pretty but will do the job
this morning i picked up a frsh cyl of gas so im gonna go crazy with the welder this weekend, gotta finish up the stiffners, cap the rockers, crossmember, floors and a lil bit of misc fab here and there Nac Fest has gotten me a lil motivated
Old June 30th, 2011, 20:25
good! the unibody run last year is what made me get rid of the subie
Old July 2nd, 2011, 16:22
ROBZ95Xj's Avatar
crossmember is done, reinforced with 1/4" plate and rod
also shortned a stock auto frt ds 4.5" to work with the atlas and frt 60
Old July 3rd, 2011, 08:29
WAD357 WAD357 is offline
nice work dude... shortening shafts is much easier then I thought it would be
Old July 3rd, 2011, 08:36
ROBZ95Xj's Avatar
yeah it is
Old July 3rd, 2011, 19:43
ROBZ95Xj's Avatar
spent the day finish welding in the stiffners damn that was alot of holes, also managed to hit the duty cycle on the welder, also capped of the rockers and primed em
my craptastic welds
capped rocker
Rate This Thread:
Jeeps on Little Planet Pic 4WDlifeform Non-Tech / Off Topic 2 November 30th, 2011 18:36
Blowing Up a $60,000 S.U.V. To Save the Planet buzzbombxj Non-Tech / Off Topic 8 July 25th, 2008 07:19
Planet Audio 12 inch sub Feeler Skwerly SoCal For Sale 0 January 18th, 2008 13:13
Planet Audio Amplifier Opinion blaisetd Non-Tech / Off Topic 3 April 25th, 2007 12:08
The Northeast Association of 4WD Clubs Cleans our Planet for Earth Day! Kejtar Land Use Forum 0 March 21st, 2003 10:55
