mbogosia
- Nashville, TN
I will have 3 of these available. These are the Ford 8.8 axles with 31 spline shafts, and disc brakes. The axles can be set up for a cherokee or we can leave them with bare axle tubes and you can set them up for something else. They will not be painted due to weather, and the insides are not being rebuilt. However, we will remove the covers and inspect them. The fastest I can have one ready would be by March 7, unless you call me too close to that day.
Set Up - Includes perches welded on, shock mounts welded on, yoke to attach to cherokee driveshaft, and brake cables. $350
Not Set Up - Includes axle as is with perches/sway bar mounts cut off. This leaves you with bare tubes to do whatever you want. $300
Post here or call/text Matt at Six 1 Five - 5 seven eight - 0 two 8 eight.
