Installed the main leaves that I removed from my BOR leaf packs last year about this time. It brought the ass end up a little but should be fine. I cut off the lower shock mounts and am in the process of fabbing up a set of lower mounts that will not hang down like rock anchors. I am designing them that if they hang down an inch or so under the axle, they will have a tapered leading edge and have a skid plate incorporated into them. I also realized a while back that my factory wiper switch has gave up the ghost as well as the washer squirters, so I need to get that all figured out before Winterfest as well. I am even thinking about a last minute design idea on a rear tire carrier.......not quite sure on that one yet though!
that looks great man! if i realized you were doing this i would have suggested what i did (which was suggested to me). Trailer spring perches are almost the perfect contour already for a 3" axle tube, weld the bolt in, weld the spring perch on and you're done!
Of course mine dont have the fancy skids, and i cant say i made them...
edit: and you guys are sick in the head haha
When I got back from WF and found the power steering line leaking on the GP, I started DDing the XJ. Something I never do. Looks like we went opposite directions.
We are in the begining phases of the Tri-State Run for this year, you better be in for this one, it is a blast! I will let a know the dates after we get them nailed down. Looks like this years locatiosn are going to be Disney, OK/SMORR/KS Rocks......
