terrehautian
- Terre Haute
Stay far away from 60°V6 GM engines (3100 & 3400 engines)......
Sounds like a vacuum leak of some sort or transmission control system problem.
If Josh keeps having kids maybe his MINI might be forsale sooner rather than later
mac 'didn't realize that they had been around since 2003' gyvr
My MJ has a 2.8......i'm well aware that they are piles.......
It means patch that sucker up as best you can and then sell it on CL for less than an idiot will think it's worth...
Can anyone lay some knowledge down on me about plumbing a fuel cell for the back of an XJ?
Damn caneuter valve bolt I bet!
Guranteed issue!
pretty sure those were the first GM engines to have the intake manifold gasket issues.
side note, back to red.
Pretty crazy seeing vendors close down. Xj scene is slowly dieing
intake gasket issues, for sure. but generally not a bad engine if you watch for intake leaks
I'm curious as to the frequency of your leaks. If a 60* 3.1, 3.4, 3100, 3400 (yes, there are significant differences in the "point" and XX00 series engines), 3800 engines will not only run fine but continue to be relatively repair free if proper preventive maintenance is performed. And switching to a newer antifreeze will go a long way. Dexcool is kinda crappy. Prestone would be my personal route in one of those era engines after doing intakes.After my third intake leak, I decided to sell my POS Malibu......
But I would honestly say that 60K is about the general time in between gasket changes. If you but 180K on a Malibu, I'm certain you had more reason to sell the car than intake leaks...
