cserou
- Sacramento, Ca
I bought some 1.5" plain steel exhaust tubing from Summit Racing(straight pieces and U-bends).
Butt welded them and used rubber hose for any joints (I wanted certain sections to be removeable for servicing other parts of the jeep). Wherever the rubber met the tubing, I ran a small weld bead around the edge of the tubing to act as a catch for the hose clamps. Works perfect. I also added a drain point at the lowest point of tubing and some bleeders in the engine bay to assist with getting rid of air bubbles.
Looking back it would have been nice to TIG the tubing since I could have forseen any leaks from the start. Had to fix one area that was a PITA.
That sounds like a really good set up. It's too bad marmon clamps probably aren't water tight...
I'm sure people thought my drivetrain would be too heavy (Probably tipping the scales at just over 1k lbs) but I haven't had an issue with it.
400+ HP and 500 + lb-ft of torque makes it feel light as a feather
Word.
I should have some pics up this weekend... It's been raining for the past 3 weeks here but it finally looks like sunshine.
