The time has finally come to upgrade the fuel system! We checked the fuel pressure while under boost recently to find out that it's falling off into the 20's
Not good at all, so I've been collecting parts recently. The plan is to upgrade the pump, add a filter and return line into the system along with all SS AN lines.
Main parts of the system going in:
AEM 320lph pump
Holly 10 micron filter
Inline check valve
heat sink cooler
Aeromotive regulator at the rail
modified factory fuel rail for -6 return
I chose to cut (carefully) a hole in the rear floor to allow for an access panel instead of dropping the tank. With the skid and hitch installed, dropping the tank would be a huge pita.
There was a good 1/2" of dirt surrounding the module, so I broke out the vacuum to ensure nothing ended up in the tank...
The pickups were nasty! I can see why the airtex replacement pickup is almost twice as big as the oem.
Pump comparison shot.
Regulator...
I'll have some more updates later this weekend. :wave:
Quick pic of the trans that will eventually be swapped in...
