BallisticDave
Follow me on Twitter!
- Tucson, AZ
We have discontinued many of our parts that were just not selling. Here is a list of what is still in stock from the discontinued items.
This is the best price you'll EVER find on this stuff, so get yours now! This deal is only good until the goods are gone!
You must call in your order 520.888.4441
Parts will ship same or next day depending on the time of day the order is placed.
Part # Nomenclature Clearance
BRK-1029 2.0 in. Tube Flange 2 bolt design (2 pieces) $5.00
BRK-1002-1 Panhard mount with 6" separation plates 2.5" Axle Diameter $15.00
BRK-1002-8 OFFSET Panhard / Tracbar Mount 3.5" axle, 6 inch separation $15.00
BRK-1003-1 Panhard mount with 7" separation plates 2.5" Axle Diameter $15.00
BRK-1003-5 OFFSET Panhard / Tracbar Mount 2.5" axle, 7 inch separation $15.00
BRK-1004-1 Link axle tower 7" separation 2.5" axle diameter $15.00
BRK-1004-11 Link axle tower 7" separation 2.75" axle diameter $15.00
BRK-1004-5 Link axle tower 7" separation 2.5" axle diameter 3.0" Mounting width, 3/4" hole $15.00
BRK-1004-8 Link axle tower 7" separation 3.5" axle diameter 3.0" Mounting width, 3/4" hole $15.00
BRK-1005-1 Link axle tower 8" separation 2.5" axle diameter $15.00
BRK-1005-11 Link axle tower 8" separation 2.75" axle diameter $15.00
BRK-1005-4 Link axle tower 8" separation 3.5" axle diameter $15.00
BRK-1005-6 Link axle tower 8" separation 3.0" axle diameter 3.0" Mounting width, 3/4" hole $15.00
BRK-1005-7 Link axle tower 8" separation 3.25" axle diameter 3.0" Mounting width, 3/4" hole $15.00
BRK-1005-8 Link axle tower 8" separation 3.5" axle diameter 3.0" Mounting width, 3/4" hole $15.00
BRK-1006-1 Link axle tower 9" separation 2.5" axle diameter $15.00
BRK-1006-11 Link axle tower 9" separation 2.75" axle diameter $15.00
BRK-1006-7 Link axle tower 9" separation 3.25" axle diameter 3.0" Mounting width, 3/4" hole $15.00
BRK-1006-8 Link axle tower 9" separation 3.0" axle diameter 3.5" Mounting width, 3/4" hole $15.00
BRK-1007-3 Lower axle link bracket 2.5" axle diameter, Ten Degree Offset, 2.63" 9/16" $15.00
BRK-1007-4 Lower axle link bracket 2.5" axle diameter, 22.5 Degree Offset, 2.63" 9/16" $15.00
BRK-1007-5 Lower axle link bracket 2.5" axle diameter, 0 Degree Offset, 3.0" 3/4" $15.00
BRK-1007-6 Lower axle link bracket 2.5" axle diameter, 5 Degree Offset, 3.0" 3/4" $15.00
BRK-1007-8 Lower axle link bracket 2.5" axle diameter, 22.5 Degree Offset, 3.0" 3/4" $15.00
BRK-1008-6 Lower axle link bracket 3.0" axle diameter, 5 Degree Offset, 3.0" 3/4" $15.00
BRK-1008-7 Lower axle link bracket 3.0" axle diameter, 10 Degree Offset, 3.0" 3/4" $15.00
BRK-1008-8 Lower axle link bracket 3.0" axle diameter, 22.5 Degree Offset, 3.0" 3/4" $15.00
BRK-1009-5 Lower axle link bracket 3.25" axle diameter, 0 Degree Offset, 3.0" 3/4" $15.00
BRK-1009-6 Lower axle link bracket 3.25" axle diameter, 5 Degree Offset, 3.0" 3/4" $15.00
BRK-1009-7 Lower axle link bracket 3.25" axle diameter, 10 Degree Offset, 3.0" 3/4" $15.00
BRK-1009-8 Lower axle link bracket 3.25" axle diameter, 22.5 Degree Offset, 3.0" 3/4" $15.00
BRK-1010-2 Lower axle link bracket 3.5" axle diameter, Five Degree Offset, 2.63" 9/16" $15.00
BRK-1010-7 Lower axle link bracket 3.5" axle diameter, 10 Degree Offset, 3.0" 3/4" $15.00
BRK-1010-94 Lower axle link bracket 4.0" axle diameter, 22.5 Degree Offset, 2.63" 9/16" $15.00
BRK-1010-95 Lower axle link bracket 4.0" axle diameter, 0 Degree Offset, 3.0" 3/4" $15.00
BRK-1017-1 Link tab (pair) 3/16" $1.00
BRK-1017-2 Link tab (pair) 1/4" $1.00
BRK-1017-3 Link tab (pair) 3/8" $1.00
BRK-1021-5 Two wrap around 1.25" link brackets (two pieces) $3.00
BRK-1021-8 Two wrap around 1.25" link brackets (two pieces) $3.00
BRK-1037-1 Coilover mount self jigging assembly (2 mounts) for 2.5" axle diameter $10.00
BRK-1046-1 Weld-on tube end (1) for 1.25" tube $1.00
BRK-1050-1 Flat bottom radius arm / coil mounts (2) 2.5" axle diameter $15.00
BRK-1057-1 Axle tube shock tabs 2.5" axle diameter 3/16" plate $1.00
BRK-1057-21 Axle tube shock tabs 2.75" axle diameter 3/16" plate $1.00
BRK-1057-5 Axle tube shock tabs 3.25" axle diameter 3/16" plate $1.00
BRK-1057-7 Axle tube shock tabs 3.5" axle diameter 3/16" plate $1.00
BRK-1058-3 Dual Flat Bottom Shock Tabs - 4" Length $5.00
BRK-1058-4 Dual Flat Bottom Shock Tabs - 5" Length $5.00
BRK-1058-5 Dual Flat Bottom Shock Tabs - 6" Length $5.00
BRK-1059-51 Axle link / coilover mount 2.5" axle 22.5 degree angle for 3.0" 3/4" joints $25.00
BRK-1063-1 Radius Arm - Coilover/shock mount 2.5" axle $25.00
BRK-1063-3 Radius Arm - Coilover/shock mount 3.25" axle $25.00
BRK-1063-4 Radius Arm - Coilover/shock mount 3.5" axle $25.00
BRK-1065-6 Universal long tab 3/8" plate 1/2" hole $1.00
BRK-1067-1/2 Flat bottom radius arm mount 2.5" Axle tube 2.5"/3.0" Mounting Width $15.00
BRK-1074-6 HD Link Tabs 1.5" Long $5.00
BRK-1076-1 Link Tabs 1.75" Short 1/4" $5.00
BRK-1076-2 Link Tabs 1.75" Medium 1/4" $5.00
BRK-1076-3 Link Tabs 1.75" Long 1/4" $5.00
BRK-1076-4 Link Tabs 1.5" Short 1/4" $5.00
BRK-1076-5 Link Tabs 1.5" Medium 1/4" $5.00
BRK-1076-6 Link Tabs 1.5" Long 1/4" $5.00
BRK-1077-6 High Clearance Shock Tab 2.0" $1.00
BRK-1079-1 HD Tie Down Tabs - 2.5" axle (pair) $3.00
BRK-1079-3 HD Tie Down Tabs - 3.25" axle (pair) $3.00
BRK-1079-4 HD Tie Down Tabs - 3.5" axle (pair) $3.00
BRK-1080-3 Axle tube LINK Tabs 2.75" (pair) $1.00
BRK-ROC-1108-4 Rockwell Link bracket w/ Coil mount 3.0" mounting width 3/4" hole NEW 15 degree ANGLE $30.00
BRK-ROC-1111-2 Rockwell Link bracket w/ COILOVER mount 3.0" mounting width 3/4" hole NEW $30.00
DIF-2004-2 Eaton Differential Cover - 3/8" Steel - WELDED and MACHINED $80.00
DIF-2005-2 Dana 35 Differential Cover - 3/8" Steel - WELDED and MACHINED FLAT $69.99
DIF-2009-2 Xterra C200 Differential Cover - 3/8" Steel, M10 Bolts - WELDED and MACHINED FLAT $75.00
DIF-2010-3 AAM 9.5 Differential Cover WELDED $80.00
HMS-519 High Misalignment Spacer for 7/8" bore to 1/2" (303 SS) $5.00
HMS-520 High Misalignment Spacer for 1.25" UNIBALL to 3/4" (303 SS) $5.00
MISC-621-1 Billet Steel Tube Caps 1.0"-1.25" $1.00
MISC-621-4 Billet Steel Tube Caps 1.75"-2.0" $1.00
MISC-621-8 Billet Steel Tube Spikes 1.75"-2.0" $5.00
SAF-682 303 Stainless Steel 1/2" Safety Washer $2.00
SAF-683 303 Stainless Steel 7/8" Safety Washer $2.00
SPA-550-1 Universal Spacer 9/16" bolt hole 5/16" width $2.00
SPA-550-5 Universal Spacer 3/4" bolt hole 5/16" width $2.00
SPA-550-6 Universal Spacer 3/4" bolt hole 7/16" width $2.00
SPA-561 Step Down spacer 5/8" to 1/2" with 1/16" shoulder $2.00
SPA-563 Step Down Spacer 5/8" to 1/2" with 1/4" shoulder $2.00
SPA-566 Step Down Spacer 7/8" to 5/8" with 1/16" shoulder $3.00
SPA-567 Step Down Spacer 1.0" to 5/8" with 1/2" shoulder $5.00
SPA-568 Step Down Spacer 1.0" to 9/16" with 3/8" shoulder $5.00
SPA-580 Reducing Spacer - 9/16" to 3/8" (CRS) $1.00
SPA-591 Reducing Spacer - 7/8" to 3/4" (CRS) $1.00
SPA-592 Reducing Spacer - 1.0" to 9/16" (CRS) $1.00
SPA-595 Reducing Spacer - 1.0" to 7/8" (CRS) $1.00
LIMITED QUANTITIES! Call now for the best deal EVER!!!
