ZJ project ready for tube.
badgeye
Bakersfield, Ca
Due to loss of interest I will be selling my ZJ project. If you are handy with a bender this may be the jeep for you.
93 zj w/ 4.0 and auto trans
231 transfer case w/ slip yoke eliminator
High pinion disconnect 30 with 4:56 gears (installed)
Non disconnect high pinion 30 with 4:56 gears and drop-in locker(un-installed)
New set of Ten Factory axles w/ stubs & u-joints (un-installed)
Rear Dana 44 (not aluminum) with 4:56 gears and Lockrite
Alloy axles for rear Dana 44 (not installed)
Eaton E-locker for Dana 44 (not installed)
PRP seats mounted on ZJ electric seat tracks
Rockers have been cut out and replaced with 2x6 3/16 wall tubing
Front grille has been replaced with custom grille made from 2 military jeep grilles
New set of anzo halogen headlights
It has american racing wheels on it with 35 inch older BFG's
I have an aluminum RCI fuel tank for it, but also have a stock fuel tank in case you need to register in in California
Currently has Idaho tags.
I think that is the full list, if I tink of anything else I will post. I prefer to sell as a package at this point. First $1000.00 takes it. Just trying to raise some cash for a dirtbike.
yea a bit far for me, but close enough, i'd love to put all those goodies into my xj
There are different width rear Dana 44's from different vehicles. I am trying to make sure the rear is a XJ D44. In which case he would have swaped control arm mounts and coil buckets onto the XJ D44 to make it work in the ZJ I would assume.
I'm assuming that the front axles are non-disconnect correct?
The front axle that is in it is a disconnect that is geared (4:56) and open. It has an additional non-disconnect axle (not installed) That is geared (4:56) and locked (lock-rite) but has no outer c's, brakes or shafts. There is a set of non disconnect Ten Factory axles that are new in box.
So just so I have this right in my mind you have front TF non-disconnect axle shafts (assuming stock spline count outer and inner) new in box, used rear Superior axle shafts (again assuming stock spline count) and a (new in box?) Eaton E-locker for the rear D44 (stock spline count)?
