ZJ disk to Chrysler 8.25 question
No need to open up the bolt holes, just the center hole. I used 2 grinding drums on a dremel and it took maybe 10 minutes. It's great that the libby brackets fit without grinding but I couldn't find any for 6+ months, while I had 8 or 9 ZJs with discs to pick over any time I went to the yard.
As noted you WILL need the studs from the flange that the brake backing plate bolts to. The disc ones are longer than the drum ones and you won't get sufficient thread engagement if you use the stock studs. They are splined and pound out easily, make sure you don't screw up the threads pounding the ones out of the donor axle. I used a punch on the center of the end of the stud so that I didn't have to be quite as careful.
So, I've upgraded to a WJ master, ZJ prop valve, and ZJ rear disks. I originally had a problem with air in the lines, but I used a power bleeder to purge them. I think all the air has been removed, as the pedal is rock hard when the engine is not running. However, the brakes are soft when the engine is running/boost is on. It seems to stop okay (I can't tell if better/worse, since I haven't driven it in a few months), but I absolutely can not lock up the brakes, even on wet pavement (I used to be able to lock up the rears. Should I be expecting better/worse than this?
