Jeff 98XJ WI
- Butternut, WI
Hey all, my friend has a ZJ with the aluminum D44 and she has experienced quite a bit of noise from the rear end. She was told it was a pinion bearing, so she had that replaced at a shop. It seemed to quiet down for awhile, but then the noise returned. I drove in it yesterday and the gear noise is BAD. Starts right as the vehicle begins to move. So, what are her options for fixing this? Would a TJ D44 rear be a good choice for a direct swap? Where can one find one of these? What is the cost? She was quoted something like $900 for new gears to be installed and I couldn't tell you if the problem is really the gear set or the setup of the gear set or the bearings or a bent housing or what. All I know is that general consensus is that the Al. D44 is junk and hers has problems. Thanks for any input. Jeff
