YJ rear brake line won't work on XJ
camarors8992
I'm replacing the 8.25 under my 98 xj so i wanted to redo the replacement ( rockcrusher cover, new brakes, brake lines ect... and the YJ line i was given at autozone will not work on my 8.25 axle. I got the brake line for an 89 wrangler, what year do i actually need to work ? The vent is bigger on the 8.25 and the block is larger on the 8.25 brake hose as well.
Here's some more info:
Stock 98 XJ Rear Brake hose
#70493
14.5" long
Stock 91 MJ Rear Brake hose
#78115
17.5"
Stock 89 YJ Rear Brake hose
#77523
15.25"
I've got part # BH2151960 from O'Reilly's and a quick google search yields it's the same part number for 1994 YJ and 1990 MJ. I'm about to install it on my 2001 XJ with 8.25. And after that, replace the hard line to the rear junction. Not coll that it completely disintegrated when trying to pull just the soft line...
See first two results:
https://www.google.com/webhp?source...enUS607US608&ion=1&espv=2&ie=UTF-8#q=bh251960
