Still trying to chase down the cruise control problem on my '89, (4.0, AW-4, NP231) no luck so far and I'm considering an aftermarket replacement... The story so far... fuse OK, vacuum OK (at least I assume 16 in. of vacuum at the servo is OK), switch on stalk is OK per all the continuity tests in the manual. I got a spare module and servo from the boneyard on the cheap, swapped out in various combos, no soap. Been systematically testing with a volt/ohmmeter as per the factory service manual. All the tests are OK so far down to the one for the vehicle speed sensor, which should show 30-50 ohm resistance (IIRC), but shows none - so I'm hoping it is the culprit, though I swear it tested good the first time through. Anyway, I went to the parts store to see what one would set me back and they only have them listed back to '91, why do you suppose that would be??? It's about a $60 part at the dealer, so I'll probably be crawling back under the ones at the boneyard some more...
I've been looking at aftermarket systems, and I wonder if anyone here can tell me if they're any good? There are some pictures in the J.C. Whitney catalog, and some look remarkably similar to the factory one. I wonder if one of those could use the existing switch (which tests perfect) instead of having to tear the steering column apart to put a new one in??? Any guesses??? Some of them say they use the existing speed sensor, so I'm probably going to have to deal with that anyway, but I was wondering if anyone here had any experiences to relate along this line???
Thanks!
Marty
Thanks!
Marty
