yet another 44/60 frankenaxle!!!
Gil BullyKatz
You big boys might not be impressed but me....
Wow.
attachment.php
http://www.pirate4x4.com/forum/showthread.php?t=417688
besides previously owning a hp44 center section are there any other reasons somone would choose a 44 center section over a hp60 center? ground clearance?
Ground clearance, weight, and fitment.
thanks thats exactley what i figured, thought there might be somthin i was missing. now im curious what the weight difference is in just the center sections
XJ_ranger said:
nice piece of fab work, but imho portals are gay. Their is a ton of torque being applied to links and the COG has to be higher than a 60. They are great for ground clearance but it is much harder to work around them, that is why the comp. guys quit using them. Don't take my word for it, this is the "three week jeep", Jake Hallenbeck (competition driver, in case you don't follow rock crawling) built it in his shop and hates the axles. There aren't any lockouts, the lockers don't work half the time, and he broke a .250 wall link from the torque. I will stick to a tried and true dana 60 and 14 bolt if I ever go one ton :P
attachment.php
attachment.php
and the link in case any one is interested.
http://www.reno4x4.com/forum/showthread.php?t=1102
Not trying to put you down, I just say don't hop on the portal wagon until you do some more research ;) That is nice work on that axle BTW, but I like nolan's high 9 better :D
There is none. Like even and odd, it's just an illusion.
Go get yourself one one, of each.
And, you know, without pics of both mounted up with 5 links, this belongs in mod tech. :D
--ron
Seems like a pretty expensive piece to be using stock-style C.A. bushings.
No kidding. May be one of those way more money than experience TJ drivers.
davidt said:
nice piece of fab work, but imho portals are gay. Their is a ton of torque being applied to links and the COG has to be higher than a 60. They are great for ground clearance but it is much harder to work around them..
Portals are only gay if you can't afford them or don't know anything about them. The COG is lower because the weight of the portals keeps it low. My rig is about 3" narrower and 4" taller than last year and is just as stable on side hills. They are a little more challenging to set up the suspension with but that just takes more thought and planning. Then again, maybe I just don't know what I'm talking about.
http://www3.telus.net/public/xtremexj/exo3.JPG
http://www3.telus.net/public/xtremexj/exo6.JPG
All I know is that axle makes me horny
I saw your buildup on Pirate and it is very impressive. Very nice rig!
I hope to build a portal'd rig in the future.
To avoid them because they are hard to set up is asinine.
