Figured I would throw up what it takes to install this cage as I didn't find much in my research.
Kit is bent and coped, 1.75"-.120 wall DOM.
The main roof hallo is cut into 3 pieces for shipping, so first step is to weld this together. It comes with sleeves, I also added some plug welds.
Put the rest of it together, but just tacks incase it needs to be adjusted.
Marked out the roof.. no turning back..
I was really carful when I drilled the holes to not punch through the headliner. I then cut back the headliner backing so I could neatly cut and fold back the headliner fabric and glue it in place. This will trap the headliner but if I had to remove for some reason I can make cuts later...
B Pillar
The kit comes with plates you can weld or bolt to the floor for the B and C pillar to land on. I wasn't about to rely on sheet metal floors to support a cage so I spent some time to make proper landings.
B Pillar...
C Pillar...
B Pillar
B Pillar...
C Pillar...
