XJ will crank but wont start :(
BiggJohnson06
Ohio
the other day i was driving downt he road when my 91' XJ laredo 4.0 just stopped while i was driving... pulled over the motor would crank just fine but it wouldnt start.. first guess was fuel pump/ filter.. got a brand new pump and filter still wouldnt fire checked the relay for fuel pump and auto shutdown both were fine changed all plugs/wires dist. cap and rotor still wont fire except if i pour gas directly into the throttle body it will start until that gas burns up so its not getting gas somewhere alone the way but the lines arent clogged i ran a air compressor hose through both send and return line both were clear does the xj have a fuel cutoff switch somewhere or does anyone know what it could be
A year model would help. On at least the earlier years there was a ballast resistor on the drivers side fender well.
That drawing is of an 87-90, your 91 is an H.O., Check to see if you have fuel pressure/spark, and then try the crank position sensor. I think it's located on the top of the bellhousing. Never been that deep into an H.O.
Ecarlcl
