doaxj
- dayton ohio
does anyone know of an up grade for a drag link on a 90 cherokee thats worth the money?
RobertF said:My 88 XJ drag link was 20mm dia. at the adjuster threads, this is where they bend sometimes. When it came time to replace it I found the 97 TJ's draglink to be 22mm dia at the threads, adjuster sleeve and TRE, and interchangable as a set. Spicer #410-1043 for draglink, #410-1476 for pitmam arm side TRE, and #425-1017 for the adjuster sleeve. Iv'e had people tell me they're all the same, but go measure them, it's hard to eyeball 2mm, but it does make for a stronger draglink assembly.
XJJJ said:Since the Currie complete steering assembly is designed the same as the factory steering, except obviously alot stronger, wouldn't it limit your droop on the passenger side just like the stock setup? I have 8" lift & that's the problem I'm running into. I'm looking for a solution & ruled out the Currie setup for this reason. Am I wrong?
Goatman said:Like the above pics show, the Currie setup is designed to handle a higher lift (look at the angles of the tie rod ends). However, to properly set up steering on an 8" lifted XJ requires that you use/make a custom over the knuckle design. The Currie system was originally designed for TJ's, which have a lower steering angle than an XJ to start with, and don't get lifted as high. The Currie is a good way to go, but not ideal for an 8" lift.
XJBill said:Is this something to seriously consider for a 6" lift or does the stock one work ok?
vintagespeed said:Nothing pre-made is going to work with extreme droop. The Currie unit is probably only good for 4.5" with extreme droop. When you add some lift you're not going to get anymore droop out of it, you're just adding stress to the box/frame (this is bad). Yes, it's better than stock steering but not by more than a couple inches. Build your own hi-travel steering setup you'll be much happier.
-jb
ECKSJAY said:So you're saying that you didn't like your Currie setup?
vintagespeed said:No actually I ordered one when it was "vapor-ware" and never got one. I'm glad I didn't. It's stout hardware, but they recommend it for 6" (?) and lower TJ and they dont ever offer it for the XJ, if you think about the steering box location on the TJ vs. XJ, you'll know why you're losing inches. I'm not saying it's a bad setup for the lesser-flexed rigs, but if you're at 7" and expecting some droop out of your steering then custom is the only way to go.
